check for a vacuum leak first,transmission has a vacuum solenoid on it right by the muffler shield. the cruise control, brake booster,fuel pressure regulator(on left side of fuel rail just below the fuel pressure (schrader) test orifice),the pvc as well as the dashboard selector itself (is a vacuum actuator) devices the rear heater box on xl models(behind panel right behind driver seat) has a flap door that moves ,you can see its elbow pointing backwards almost behind the unit to the left side of the unit about mid high and you should see it move as you adjust the heat selector,(floor is best heat output available from rear) the vacuum line also controls the water shut off valve right under the vehicle over there each are vacuum controlled devices
Mar 3, 2009 at 11:29 PM
