1993 Ford Aerostar Hard to start
1993 FORD AEROSTAR
87,911 MILES • 6 CYL • 2WD • AUTOMATIC
SAMANTHA CHAFIN
When the engine sits for longer than 10 mins, takes about 4-7 tries to get it started. I can hear the fuel pump running, and relay click. After it finally starts it misses but does not usually die out. When it warms up and i shut it off has no problem restarting immidiately. Have fiixed 4 vacuum leaks, adjusted timing, changed trottle pos. sensor, air temp sensor,did full tune up,o2 sensor, and still no change. What else is left??
May 14, 2010 at 2:52 PM
Have you checked fuel pump pressure?
May 26, 2010 at 1:31 PM
