van starts, runs fine til you put in gear. then it dies.
husband states that he does not hear a sound from the back when he turns on the ignition anylonger either (I believe that is the fuel pump priming)
I would like to ck the fuse first, do you know which one it is? Location? on the fuse panel?
Next I told him it is probably the fuel pump. I have some experience with this. If I remember right it is on the top of the gas tank and to change you need to drop the tank and remove from the top.
Is this a "easy" job to replace fuel pump, or "really difficult"?
He has changed plugs, oil, and ful filter. (filter was clean, but changed anyway.) Also changed the heater core a year ago.
The question I saw on your list mentioned resetting something also, could you ellabrate a little please?
Also do you have any websites that would show a picture of the assembly of tank and pump so he can get a picture of what he is getting into.
He speaks spanish and I have to translate, it is easier with a picture to show him what needs to be done.
It is not used very often and the last time he moved it it ran just fine.
I have also checked for foul play ie: suger in tank, but do not see anything
Nov 21, 2008 at 8:04 PM
