my power windows won't work,I direct wired from the battery to the window motor,it worked next I direct wired to the window switch and engaged to down position,motor worked,I don't have any voltage to the driver door switch,I checked voltage at the fuse and only get 4 volts.Is there another voltage regulator or relay for these windows?. The passenger window will not work on it's own independent switch.My wife says both windows stopped working at the same time(it's her car).Any power you can direct on the subject would be greatly appreciated, thanks Barry.
Aug 16, 2008 at 7:33 PM
