have bad leak coming from the back of the engine between the bell housing and engine. water drains out at about one gal. per 10 min. and most of the water in system drains out when the car is off and parked. The drain rate stays the same moving or parked.
I got under van and looked to see where water was coming from also took engine cover off inside and look at back of engine and saw no water. What could be the problem and what would (about) the cost to fix it.
Aug 16, 2008 at 4:22 PM
