1989 Ford Aerostar heater blows cold
1989 FORD AEROSTAR
170,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHBEY
  • 4 POSTS
why doesn't my heat work? replaced the thermostat,reconnected the hose from the blower.
Feb 11, 2009 at 2:30 PM
Hi:
With the engine hot, running, and the heater on high, check to see if both heater core hoses are hot.
Let me know what you find.
Feb 24, 2009 at 9:44 AM
JOHBEY
  • 4 POSTS
both heatercore hoses are hot and heater core also. air blows over heatercore left to right but not comimng out hot. checked control arms, moves damper ( little door behind heatercore) but still no hot air reaching heater vents
Mar 1, 2009 at 7:44 PM
Are you sure the blender door is working. THat is what determins if you get heat or cool air.
Mar 2, 2009 at 10:28 AM
JOHBEY
  • 4 POSTS
where is it located and what position should it be in
Mar 3, 2009 at 3:09 AM
It should be located on the same housing that the heater core is in. Exact position, I can't say but it should open and close when you change from cold to hot.
Mar 3, 2009 at 10:12 AM
JOHBEY
  • 4 POSTS
thanks there's a pen in there
Mar 3, 2009 at 5:46 PM
