A good battery died overnight. After recharging the battery the van started ok and ran ok and alternator charging ok. Then with engine off we found a 3.8 amp current draw with the ignition and all accessories off. We pulled all the fuses in the fuse block under the dash and the 3.8 amp draw was always there. Starter solenoid is ok. Is there something that commonly shorts out on an Aerostar?
Thanks.
Thanks.
Jul 3, 2008 at 7:35 PM
