99 Mustang - loses acceleration
1999 FORD FIVE HUNDRED
RATHEZA
Over the past two or three weeks, at intermittent times and without any apparent common ground, my 99 Mustang (v6, 78k mi) will stop accelerating. I hit the gas, sometimes it will rev, sometimes not, or not convincingly. I pull over...when I bring the car to a full stop, the engine sounds like it's seizing, and I'll shut the car off. However, I don't even have to wait two seconds before I start it up again, and everything's fine until the next time it happens again - two days later, five minutes later - like I said, no common ground such as running hot, idling, taking a turn, etc. I replaced the cooling fan last weekend after the a/c wasn't coming on (or would come on/turn off/come on/turn off). After replacing the fan, the a/c works fine until the problem above occurs, and it too acts up along with the engine - these problems pretty much started at the same time, and I thought both would be fixed by replacing the fan. Thanks in advance for your help.
Apr 17, 2007 at 3:07 PM
MERLIN2021
  • 17,250 POSTS
When it happens does it seem like a heavy electrical drain?
Apr 17, 2007 at 3:32 PM
RATHEZA
that's actually not a bad way to describe it - actually, pretty accurate. it's like the car is running at 75%...
Apr 17, 2007 at 5:06 PM
