2007 Ford 500 Car jerking
2007 FORD FIVE HUNDRED
54,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANTHONYZACH
Hello, I have a 2007 Ford 500 SEL V6 2 wheel drive. I recently started having an issue when I turn the car on and when switching to drive car jerks it also happens when i'm at a stop and drive again or when I park it jerks. It seems it is getting a bit more worst today while driving there was a point where it did not want to accelerate then when stopping it wanted to keep jerking to where i stop and it kinda drag forward a bit. I had the codes check with nothing, transmission and engine fluids are good and also had the fuel filter replace. I have a feeling this might be Mass airflow censor or so.. Have any ideas? specially since after running a scan there are no codes return and no lights turn on the dash board.
Aug 14, 2010 at 8:23 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would start with cleaning the throttle body, use a quality cleaner you can get it from any parts store, when this is done pleas advise any change and what the idle speed is.
mark (mhpautos)
Aug 14, 2010 at 11:32 PM
