2005 Ford 500 Power steering
2005 FORD FIVE HUNDRED
KEEGANCURTIS
2005 Ford 500 132000 miles
2005 ford 500 132k miles
Power steering problem
Steering is whining on both left and rights terns low and high speeds
PS fluid is at operating level to me it seems the pump is starving for fluid
No leeks, tires have 10K, never damaged; brakes are about due, steers straight no pulling id say alignment is spot on, we are in MN and the car will sit out during the day and the problem seams to get worse when car is warm and driven for 10-20 minutes
Has there been an obvious fix?
Jan 20, 2010 at 10:43 AM
MERLIN2021
  • 17,250 POSTS
Seems there is a known issue for the return hose, I sent you a PDF with the technical service bulliten about it...
Jan 20, 2010 at 10:58 AM
KEEGANCURTIS
Thanx for the fast reply I will pos on the results that get found.
keegan curtis
Jan 20, 2010 at 11:04 AM
MERLIN2021
  • 17,250 POSTS
Your welcome, I'll be here...
Jan 20, 2010 at 11:21 AM
