Please note that the headlights need to be switched on in order for the fog lights to work.
Please see image1+3 below.
There are 2 fuses for the fog light relay, circled in red.
First check that these are in order.
Next check that the fog light switch switches a ground on black/red wire when activated.
This can be done by using either a test light or a voltmeter.
and
and
If a ground is switched to the passenger junction box next check that the junction box outputs a ground to the fog light relay on the black/red wire.
The relay layout should be constant 12V at terminal 30, red wire.
Switched 12V at terminal 86, red/black wire from head low L fuse, 10A.
Switched ground at terminal 85, black/red wire from passenger junction box.
12V output at terminal 87 via red/green wire to front fog lights.
To test the fog light circuit you could bridge terminal 30 and 87 at the relay.
The fog lights should illuminate.
See image 2 for a basic relay layout.
Hope this helps.
Cheers, Boris
Aug 10, 2022 at 8:55 AM
