DRL lights not working
2003 HUMMER H3
101,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
BADGERONE
Fuse is okay. installed new bulbs.
Jan 13, 2019 at 6:10 PM
There is a parking lamp relay that needs to be checked. here is a guide to help you and the location of the relay. Also the wiring diagrams for the fog lights which they call clearance lamps so you can see how the system works.
Check out the diagrams (below). Please let us know what you find.
Jan 14, 2019 at 12:49 PM
BADGERONE
Hello Ken, I found out that the DRL lights work with light switch in the auto setting and the transmission in drive , but the lights still does not come on. Gerry V.
Jan 15, 2019 at 10:52 AM
If the relay is okay is sounds like the BCM has gone bad. I would try a used or rebuilt unit to see what happens. here is its location. Check out the diagrams (below). Please let us know what happens.
Jan 15, 2019 at 10:57 AM
