That harness is controlled by the body module and that has to be programmed to enable the fog light circuit to operate. As your vehicle didn't have fog lights it was never activated.
The fog light switch is part of the multifunction switch assembly and also is required for the lights to work along with the fog lamp relay.
Now if you still wanted to use the factory wiring and control of the fog lights with the low beam lights turning it on you could add a switch to the wire that comes off of terminal 2 of the fog lamp relay. If that switch was wired so it provides a ground when on and opens when off the relay will turn on when grounded and you have fog lights with low beams. That is what the OE switch does, it tells the BCM to ground the fog light output and turn the lights on.
Jun 24, 2021 at 11:54 PM
