Fog light
1997 ACURA RL
106,000 MILES • 3.5L • 6 CYL
KEN MALLARI
My fuse keeps on blowing i think i have a ground somewhere.
Apr 9, 2017 at 10:10 PM
STEVE W.
  • 15,113 POSTS
Very possible. Those can be tricky to find. There are a few tools that can make it easier though. Some parts stores even have them as a loaner tool. The one I have used for a long time is like the picture. The tube with wires is a self resetting circuit breaker. In use the circuit breaker replaces the fuse, as it trips and resets it creates a magnetic field in the wire which makes the needle oscillate. You just follow the wire and when you get to the short the needle stops.
The other type uses a radio signal and a receiver that you use in much the same way.
Both are a big help with shorted wires, the radio version however can be used for finding open circuits as well as shorted.
Looking at the diagram it appears that a short would be in the light green wires. Should not be hard to trace the wire from the light and see if it is pinched, chaffed or damaged.
Apr 10, 2017 at 3:06 AM
