Fog drops leak through back shield of the car
2018 SUZUKI SWIFT
22 MILES
DRAMIT SHARMA
back shield of the car, leaks with fog as the fog water enters into the backshield of the car.
I got the shild glass removed and fixed again, still the water of fog can be seen inside the car through the back shield.
What could be the solution of the problem????
Dec 22, 2019 at 3:24 AM
Is the vehicle still under the manufacturer's warranty? If so, they are required to fix it. When you get water in the vehicle, it can be a few different things causing it. Since you already had the rear window removed and reinstalled and that didn't fix it, check weather stripping. Can you tell if it is coming in high on the glass or low?
Dec 22, 2019 at 8:12 PM
DRAMIT SHARMA
It’s coming in high. But if it’s washed with water , water doesn’t enter inside. Neither rain can do that. Parking car at night causes this in foggy nights. Suggest what to be done?
Dec 23, 2019 at 3:30 AM
Then it isn't a leak, but rather condensation. What are the temps where you are located? Is it hot during the day and then cool off?
Dec 23, 2019 at 11:01 PM
