Can the flywheel flange be removed from the crankshaft using a harmonic balancer puller tool?
1989 FORD RANGER
150,000 MILES • 2.9L • 6 CYL • 2WD • AUTOMATIC
CUCA
  • 6 POSTS
Can the flywheel flange be removed from the crankshaft itself using a harmonic balancer puller tool, and if yes then wats the process to install the flywheel flange back.
Sep 27, 2024 at 5:13 PM
Hello, the short answer is no, sorry, it is part of the crankshaft. What seems to be the problem? Please upload pictures or videos in your response of any problems so we can see what to help you with.
Sep 27, 2024 at 5:15 PM
CUCA
  • 6 POSTS
replacing the rear main seal, but it's behind the flange not around it.
Sep 27, 2024 at 5:18 PM
CUCA
  • 6 POSTS
In one of your links, I see that you have the flange #6434 by itself.
Sep 27, 2024 at 5:20 PM
Yes, that is a newer crankshaft with a one-piece main seal, yours has a two-piece rear main seal like the one in this video.
https://youtu.be/ubgZ13Br9Pw?si=E1Ch9AXjZCXSU2nR&t=208
Can you give me the link to what you are saying?
Sep 27, 2024 at 6:10 PM
CUCA
  • 6 POSTS
It is a one-piece rear main seal even if it is a newer crankshaft how are you to replace the seal?
Sep 27, 2024 at 6:20 PM
CUCA
  • 6 POSTS
Item # D4ZZ6434A FORD FLYWHEEL FLANGE.
Sep 27, 2024 at 6:22 PM
CUCA
  • 6 POSTS
I will try to send pics of what I mean. thank you
Sep 27, 2024 at 6:25 PM
I see what you are talking about, I have never used one of these, so I was a little shocked. It looks like a spacer for what I do not know. Check out the images (below). Please let us know what happens.
Sep 28, 2024 at 10:45 AM
