What I have is for a shop lift. However, these are the lift points for front and real. Once lifted, try to place the jack stands as close as possible to the lift points. If you can't get them there because the jack is in the way, find a solid place on the subframe. Just make sure to position the jack stands in a manner that will support the vehicle. You want as much distance between them as possible for stability.
______________________________________________
2013 Kia Truck Sorento 4WD L4-2.4L VIN 6 (GDI)
Lift and Support Points
Vehicle Steering and Suspension Wheels and Tires Vehicle Lifting Service and Repair Procedures Lift and Support Points
LIFT AND SUPPORT POINTS
Lift And Support Points
WARNING:
When heavy rear components such as suspension, fuel tank, spare tire, tailgate and trunk lid are to be removed, place additional weight in the luggage area before hoisting. When substantial weight is removed from the rear of the vehicle, the center of gravity may change and can cause the vehicle to tip forward on the hoist.
NOTE:
- Since each tire/wheel assembly weights approximately 30lbs (14kg), placing the front wheels in the luggage area can assist with the weight distribution.
- Use the same support points to support the vehicle on safety stands.
1. Place the lift blocks under the support points as shown in the illustration.
2. Raise the hoist a few inches (centimeters) and rock the vehicle to be sure it is firmly supported.
3. Raise the hoist to full height to inspect the lift points for secure support.
see pic 1
I hope this helps.
Jul 29, 2020 at 8:06 PM
