Car flooded in Imelda. ruined the ECM. Purchased plug and play ECM. The car will crank and start and run until, I think, the ECM gets the signal that the car is running and the car shuts down. this all takes place in about 1 to 2 seconds. If I turn the switch to off will start again. If the key is left in the on position will crank but will not start. Checked all fuses and relays. I have disconnected every connector below the flood line cleaned as well as I could and used dielectric grease on reassembly. I indicated in the next field I was a certified mechanic. Not cars though, I was a heavy truck certified master mechanic before I retired. Thought I would add that after it stops running the spark plugs no longer fire until the key is turned off after that turn to crank position spark plugs fire until it quits running again.
Oct 16, 2019 at 6:24 AM
