Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-150
Engine
Flywheel
Bolt
Torque
Flex plate torque specs needed?
2016 FORD F-150
190,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
[email protected]
MEMBER
FOLLOW
What's the torque spec for the flex plate to crankshaft bolts?
Mar 11, 2025 at 5:40 AM
CERTIFIED EXPERT
Sure, this bolt is torqued to yield and are not re-usable. Flex plate torque specs.
Install the flexplace and the bolts.
Torque:
Stage 1: 20 Nm
Stage 2: 60°
Here is the tightening sequence. Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Mar 11, 2025 at 1:58 PM
[email protected]
MEMBER
Thank you very much.
Mar 11, 2025 at 6:27 PM
CERTIFIED EXPERT
You are welcome, please use 2CarPros anytime we are here to help.
Mar 12, 2025 at 10:20 AM
