Flex pipe replaced four times within five years
2011 CHEVROLET MALIBU
136,000 MILES • 2WD • AUTOMATIC
CHRISTINE542!
  • 5 POSTS
I am not sure why this keeps happening. Last time, I also replaced the motor mount hoping that this would prevent further issues. The repair shops have not indicated any underlying issues just the flex pipe. I feel like there has to be something else going on. It does not appear to be a common issue. Do you know what could be causing the flex pipe to wear out so quickly?
Jan 28, 2020 at 5:52 PM
CHRISTINE542!
  • 5 POSTS
Hello. Yes, it’s part of the muffler/exhaust. Thank you!
Jan 29, 2020 at 2:54 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
As a general rule, flex pipe doesn't have the life expectancy that regular exhaust pipe has. This is do to it's nature, it is flexible, so in order to make it flexible, thinner materials are used. Thinner materials with multiple joints that enable the pipe to flex is not going to withstand the constant heat of a vehicle's exhaust as a thicker solid piece of exhaust pipe. It's just the nature of the beast. I would recommend seeing if there is any way of getting exhaust pipe bent to the specs you need and give that a try.
Thanks,
Alex
2CarPros
Jan 29, 2020 at 3:36 PM
CHRISTINE542!
  • 5 POSTS
Thanks so much Alex!
Jan 29, 2020 at 4:04 PM
Good evening,
Just wanted to add to Alex response.
A lot of the times, those flex pipes fails from too much movement from the engine. Weak motor mounts will cause the pipe to flex way too much and it fails.
The reason for the pipe is movement of the engine. Since it sits sideways, it moves and if they did not have a flex pipe in the system, a pipe would actually fail.
Jan 30, 2020 at 7:12 PM
CHRISTINE542!
  • 5 POSTS
Thanks Roy. Last time, I did have the motor mount replaced with the flex pipe. This is why I was so surprised this happened again so quickly. It hasn’t even been 1.5 year this time.
Jan 31, 2020 at 9:53 AM
There are several motor mounts on the engine. You have 3 mounts on the transmission and 1 one the engine. Any one of them with too much play can cause this issue.
Jan 31, 2020 at 10:19 AM
CHRISTINE542!
  • 5 POSTS
Thank you for explaining.
Jan 31, 2020 at 2:48 PM
You are welcome.
always glad to help.
Jan 31, 2020 at 2:56 PM
