Hello, this is Tom.
Here are the issues that can be the cause for your code it can be many things so we will have to go through to figure which is yours. Review this list of symptoms and causes and get back to us with anything that sticks out to you. Giving us an idea of how this began will help as well, things like any work done lately, Did this start all of a sudden or has it been a situation that was every once and a while that has becoming worse over time or have you gone to a different fueling station than usual. Pulling a spark plug to see it condition will give us good info on the burn and whether or not you due for a tune up.
Here is a good article for your review as well:
https://www.2carpros.com/articles/engine-has-low-power-output
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
P0302 Symptoms
Check Engine Light flashing
Rough running, hesitation, and/or jerking when accelerating
In most cases, there are no adverse conditions noticed by the driver
In some cases, there may be performance problems, such as dying at stop signs or rough idling, hesitation, misfires or lack of power (especially during acceleration), and a decrease in fuel economy.
Common Problems That Trigger the P0302
Worn out spark plugs, ignition wires, coil(s), distributor cap and rotor (when applicable)
Incorrect ignition timing
Vacuum leak(s)
Low or weak fuel pressure
Improperly functioning EGR system
Defective Mass Air Flow Sensor
Defective Crankshaft and/or Camshaft Sensor
Defective Throttle Position Sensor
Mechanical engine problems (i.e.—low compression, leaking head gasket(s), or valve problems.
Common Misdiagnoses
Fuel Injectors
Oxygen Sensor(s)
Powertrain/Drivetrain problems
Polluting Gases Expelled
HCs (Hydrocarbons): Unburned droplets of raw fuel that smell, affect breathing, and contribute to smog
CO (Carbon Monoxide): Partially burned fuel that is an odorless and deadly poisonous gas
NOX (Oxides of Nitrogen): One of the two ingredients that, when exposed to sunlight, cause smog.
Get back to us with what you have figured out
Tom
Sep 21, 2020 at 9:05 PM
