Flashing airbag light
2013 NISSAN ROGUE
109,833 MILES • 4 CYL • AUTOMATIC
NYENYE
Hello, took my car in first a diagnosis, and was told it is the clock spring. My horn and everything in my steering wheel still work though. I have to get my grandma's home (500 mile trip) is it too risky to take my car? I've been told my shaft boots are in poor condition as well, but my car shows no symptoms of that either.
Thank you in advance!
Tennye
Aug 21, 2019 at 10:05 AM
If you are taking a 500 mile trip, I would suggest having both of these items corrected. More than likely you would be okay but the problem is, once the axle boots are compromised, they don't get any better. It is only a matter of time because the CV axles fail. Normally they will start to make noise and click before they fail but again, this is not something I would personally risk because they are going to need to be replaced sooner or later and having an issue on a long trip is the last thing you want to happen.
As for the clock-spring, I would have that replaced as well because when the airbag light is on, the airbags are disabled. If going on a trip, I would want to make sure these are working properly. I would assume that they have open circuit codes for the air bag which would indicate the clock-spring. However, the other steering wheel controls have their own winding on the clock-spring so they could still be working and the airbag is not.
Let me know if you have any questions. Thanks
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
Aug 21, 2019 at 4:52 PM
