flashers and turn signal not working blowing fuse
2000 CHRYSLER INTREPID
65,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
BIGMIKE3823
The turn signals and flasher quit working ckd #9 inside fuse block when I ckd #o (20) it was blown and the 2 I tried next blew also. It was actually a spark when they blew
Jul 27, 2015 at 4:35 PM
CARADIODOC
  • 34,306 POSTS
A simple trick to finding a short is to replace the blown fuse with a pair of spade terminals, then use small jumper wires to connect them to a 12 volt light bulb. A brake light bulb works well. When the circuit is live and the short is present, the bulb will be full brightness and hot so be sure it's not laying on the carpet or against a plastic door panel. Now you can unplug electrical connectors and move things around to see what makes the short go away. When it does, the bulb will get dim or go out.
Jul 27, 2015 at 5:42 PM
