I installed LED turn signals all around (2 pairs up front, and 1 pair in back which is also the brake light) and as expected, the turn signals were hyper flashing. i installed a new flasher relay designed for use with LED's. when i tested it out, nothing worked. i put the stock relay back in and that didn't work either - wasn't even getting the hyper flashing. i then put the standard filament bulbs back in (with the stock relay still installed), and thinks look like they are going a little haywire. the left signal worked but would hyper flash, the right signal wouldn't flash, but would just stay on. i turned on the headlights, and it changed things, but it still wasn't right, i just don't remember exactly what quirky thing was happening then. i checked the turn signal fuse and it was not blown. hoping this is an easy fix, just not sure where to look next. thanks!
Oct 17, 2020 at 12:14 PM
