Flasher relay problem
2003 FORD EXCURSION
175,000 MILES • 6.8L • V10 • 4WD • AUTOMATIC
SODAPOP65
Flasher relay will not stop clicking. All lights and turn signals work properly. Replaced flasher but no change.
Jun 23, 2018 at 7:33 AM
I would cycle the hazard switch many times to clean the switch contacts. Next I would remove the trailer tow relays one at a time to see if that affects it. Here is a blinker wiring diagram so you can see how the system works. Let me know if you are not on a phone and cannot enlarge the diagrams I will send larger ones.
Here are the relay and fuse panel locations as well.
Jun 24, 2018 at 1:04 PM
