Okay. This sounds like you have water intrusion in some of the electronics. It is a good thing that the engine turns over but due to this we will need the codes in it. That should point us in the right direction.
I expected you to say that it just clicks and this would mean the engine is hydro-locked. The fact that it turns over is a good thing. However, we need to get the codes and see if anything is preventing the start.
With the vehicle being so new, I would suggest taking it to a dealer. The reason is, if you had water that high and the engine shut off you may have issues past getting it started. Clearly this will not be covered under your warranty but you can submit it to your insurance. Once they have a documented issue and cover whatever the dealer finds, you can submit subsequent claims against it if there are more issues. If you don't do this and you happen to get it started, then the dealer will most likely find the damaged components due to water and they will not warranty them and your insurance will not cover them either because there was no initial claim. This will leave it to you to pay for.
The other thing that you need to think about since this vehicle is so new that if you try to repair it or take it to an independent shop that you are not using OEM parts and this will raise eyebrows as well if there are more issues in the future.
My point in all of this, is I have seen many people get stuck with large bills because something like this happened and they tried to conceal the issue. Unfortunately, there are many signs that show this type of damage that once they are found, the dealer may reject all repairs in the future.
Let me know if you can get the codes and we can go from there or if you are going to take it into a dealer. Thanks
Jul 4, 2019 at 7:12 PM
