High idle, running rich and the fuel pump is whining
1992 CHEVROLET LUMINA
167,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
JESSICA LAUBY
Use to stall during low rpm's then one day wouldn't start. Changed TPS, MAP, idle air valve, fuel pressure regulator, plugs, wires, fuel rail gaskets, fuel pump and now it's idling high, running rich and the fuel pump is whining.
Jul 7, 2019 at 1:36 PM
Good morning,
The fuel pump whining is no good. That is a sign of a bad fuel pump. It should make no noise at all.
As far as the high idle, did you check for vacuum leaks in the system?
https://www.2carpros.com/articles/engine-idles-too-high
Make sure the EGR valve is not open. If it is, that is a big vacuum leak.
Are there any codes set?
As far as running rich, did you check the injectors?
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Jul 8, 2019 at 4:13 AM
JESSICA LAUBY
It's a new fuel pump, but I also found out my buddy didn't put the sleeve on it. And I don't have access to an old version of code reader. These don't have the hookup for the new ones.
Jul 8, 2019 at 1:48 PM
Does not matter if the fuel pump is new, it should not make any noise at all.
Jul 8, 2019 at 6:26 PM
