Fixed exhaust manifold bolts now engine is knocking?
2013 DODGE POWER WAGON
75,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JASON STEWART
  • 6 POSTS
I took my vehicle to the shop for an exhaust leak at the manifold that would go away after about a half hour of driving. Not loud but very annoying. The mechanic fixed everything, put it back together and called me saying I need to come hear this. I went to the shop, and he started the truck up and it was knocking so loud like the motor was shot. A whole new noise that was never there. You would be able to hear this thing run and knock 2 blocks from there it was so loud. They shut the engine right down not letting it run long and asked me if this was like that. My mechanic that pulls a vehicle into their shop would have known right away something was wrong and definitely not an exhaust knock. Which mind you a major knock that was not there. He says to me “maybe it’s a fuel issue.” I told him it did not sound like that when i brought it in, not even close. What could have gone wrong when they removed the exhaust manifold studs to replace them? He also said he had over 8 hours in the job. What do i do and what possibly went wrong? I’m freaking out right now. I still owe $20,000 on this truck and it hasn’t even hit 80,000 miles yet.
Mar 7, 2023 at 4:42 AM
BRENDON S
  • 653 POSTS
Good morning, Jason Stewart,
Something sounds really fishy here. I can help but I need every detail about your vehicle. If you don't mind sending me your entire VIN, I can look at everything on my end and see what they did. Might be as simple as he messed up the gasket or broke an exhaust stud and is trying to hide it, I'm not sure. It's possible he got a cheaper one to save money and it isn't sealing right. I don't know this person, so I don't want to make assumptions.
It's possible it is not connected right at the joint between the manifold and the Y-pipe.
If you could send me your VIN, I will take a look from my end. Also, if you have any pictures or videos before and after his work sending those would help as well.
Thank you,
Brendon
Mar 7, 2023 at 6:38 AM
JASON STEWART
  • 6 POSTS
Yes, I will look for my VIN number. Truck is at a local small shop so I’m not sure if they would have put anything in a computer database but maybe you’ll surprise me. I run a towing company, (one man show), and my in-laws own a scrap yard. I not only do normal towing, but I also haul junk vehicles in for them. Been doing it for years so I hear and seen a lot. It almost sounds like a rod is knocking or there is metal inside the motor rattling around. It is extremely loud similar to a blown motor sound, but I am no mechanic by any means of course. I don’t have any before or after pictures of my motor area. They actually still have my truck. Here is a picture of my truck and as you can see, I take well care of it, and I don’t hit rod it at all. I actually drive like an 80 year old man lol. I know this picture doesn’t help.
Mar 7, 2023 at 2:04 PM
JASON STEWART
  • 6 POSTS
Thank you for your help. I really appreciate it. My rollback is down for electrical repairs which have been an issue since the truck was purchased 3 years ago, and they cannot find the problem. Say it may be the ECM. So, I now have no vehicle and no money rolling in. This is a rough situation for me. My pickup was driving fine. I just wanted to address the exhaust leak and now I can’t even drive it.
Mar 7, 2023 at 2:16 PM
BRENDON S
  • 653 POSTS
Sorry to hear you are down on your luck, but you have my word I will work hard and see if we can get this figured out for you.
So HEMI's especially the 5.7 have always had a tick. It is referred to as the "Infamous HEMI Tick" and Dodge admits and says it is normal. It is even in your owner's manual I believe.
What you're describing to me is something more than a tick. There is a lot of things that can cause a tick or a know all from exhaust to lifters no top end and bottom end damage.
Does it sound like it was coming from one side of the motor or the other?
I would check the condition and level of the oil as well as making sure it is getting oil pressure. Check for metal pieces in the oil such as sparkles if the is mechanical damage. Pull the dip stick and hold a bright light see if you can see and metal. Just so we can rule those things out. If they did an oil change and used the wrong oil and/or a cheap filter this will make a tick since cheaper filters don't have an anti-drain back valve. This valve keeps the oil in the motor. especially if they were starting it and shutting it back off without it building the proper oil pressure the lifters will knock on the cam until proper oil pressure is reached.
The fact you went into the shop with a slight tick that went away after warm-up and came out with a motor that sounds blown is very strange.
A broken stud will make it very loud and not seat the gasket right.
Some people put the gasket in and almost immediately rev it before the gasket warms up and blow the gasket back out. Got to let it warm up and then re-torque the bolts.
If a heat shield is loose from snapped bolts, it will rattle and make noise especially if it's coupled with an improperly sealed manifold.
I have also seen flat rate guys take out the bolt and studs for the manifold and put a prybar against the flange of the manifold and drop the gaskets in, so they don't have to take the pipe off the manifold saving time and possible broken bolts. Unfortunately, you can't clean the surface of the manifold or the engine to get a good seal for the gasket. The other problem with that is it can break the bolts at the end of the manifold causing an exhaust leak there and it will be very loud as well.
Unfortunately, it's also possible something was dropped in the motor like a bolt. Let's hope not.
Lifters are a possibility as well.
If it were me, I would check the oil for any metal indicating engine damage as well as making sure there is oil pressure. My information is telling me you should have 25-100psi @ 3000 rpms with a minimum of 4 psi at idle.
A quality oil change with Castrol, this is the brand I use. Your vehicle takes 7 quarts of 5W20. Use a good filter like Wix which has this valve in it.
Next try to run it and see if you can hear if it is isolated to a certain side of the engine. as it runs and gains oil pressure see if it starts to get quieter.
I would also make sure every bolt for the manifold and heat shield are on and where they should be. Also make sure the bolts that connect the rest of the exhaust to the flange on the manifold are not broken. I am sending a couple images from the Mopar Catalog showing all the bolts and where they should be.
Also how well do you know this shop? Do they do good work or is it kind of a clown show if you know what I mean? A lot of people can work on a vehicle but inexperience with a job like this can cause big issues when you run into an unexpected problem. You might want to have it towed to a better shop.
My assumption is they messed up this job somehow. There is no way to cause internal engine damage from doing this job unless something was done wrong, or they dropped something in the motor.
Like I said the only other thing I can think of is oil related mostly with the lifters. These lifters are hydraulic roller type lifters and can collapse. If a lifter has collapsed, you should have a misfire on one of the cylinders.
If they have an EVAP Smoke machine they can stuff it in the tailpipe tight with a rag with the engine off and fill the entire exhaust with smoke. This will find an exhaust leak quickly.
See if you can get down there and check these things or have them check them. Let me know what you can come up with. We need to start the process of elimination.
Mar 8, 2023 at 6:50 AM
JASON STEWART
  • 6 POSTS
I’m trying to find my title for my VIN. I haven’t been able to get back to the shop to get the VIN due to work. This business is very reputable, and they have always been good friends of the family as well. They have high ratings, but I know accidents can happen and I’m just hoping it’s something simple. I am going to have to get over to the shop in the next couple days and see if they figured it out or if they are just going to button it up and leave it to me to gunfire out. I certainly hope not and hope I don’t get charged for it either. I had a buddy tell me it could also be a bolt, socket or really anything that could have dropped into the exhaust manifold itself unnoticed and rattling around at the catalytic convert because it has nowhere to go. I don’t believe it’s throwing any codes and I was told because of the way these vehicles are today, if it is a lifter, rod or oil pressure, any of those sorts really, he said they should throw a code.
Mar 8, 2023 at 3:57 PM
JASON STEWART
  • 6 POSTS
I will put an update later when I am able to make it to the garage, whether they fixed it or not and let you know what the outcome was if they did figure it out so that maybe it will help someone on here one day. Thank you again for your help, I really appreciate it! I am hoping they find the problem and i don’t have to do a process of elimination myself, so my fingers are crossed.
Mar 8, 2023 at 4:00 PM
BRENDON S
  • 653 POSTS
True it could be a bolt or socket, it's possible. It should throw a code, but the ECM will need to see certain conditions before setting a code. Since you didn't have this problem when you brought it in, and they only briefly ran it there because the noise was so bad it is likely the conditions weren't met yet to set a code in the computer.
You are very welcome! I am happy to help any way I can. I hope they get it figured out and definitely keep me updated. I would like to know what was causing it.
It has been a pleasure talking to you and if you need anything please don't hesitate to reply back to this thread or ask a new question. We are here to help.
Thank you,
Brendon
Mar 9, 2023 at 1:59 AM
JASON STEWART
  • 6 POSTS
Absolutely and will definitely do. Thank you again!
Mar 9, 2023 at 4:14 PM
BRENDON S
  • 653 POSTS
You're welcome.
Thank you,
Brendon
Mar 10, 2023 at 12:51 AM
