Firing order?
2010 CHEVROLET MALIBU
100,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
JERS420
I'm looking for the firing order for my car listed above ltz.
Sep 15, 2019 at 11:05 AM
Good afternoon,
I attached the firing order for you. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sep 15, 2019 at 12:30 PM
JOEY69
Need to know the firing order.
Sep 19, 2020 at 1:40 PM (Merged)
HARRY P
  • 2,292 POSTS
Here it is.
WRENCHTECH
  • 20,761 POSTS
I believe this is what you are probably looking for.
BLAKE1985
what is the firing order for a 6 cylinder 3.1 engine
2CARPRO JACK
  • 11,533 POSTS
here ya go
https://www.2carpros.com/forum/automotive_pictures/1639_31_1.jpg
MICROPHONE DOCTOR
Six cylinder automatic 120,000 mile.s
What is the firing order for the spark plugs? when changing the spark plugs I think the firing order got mixed up.
BLUELIGHTNIN6
  • 16,542 POSTS
Firing order for the 3.1 liter is below. 3.1 liter engine: Firing order: 1-2-3-4-5-6. Distributor-less ignition system.
https://www.2carpros.com/forum/automotive_pictures/261618_0900c1528024baf7_1.jpg
Thanks for using 2CarPros.com!
ALDEAN49
Engine Performance problem
2000 Chevy Malibu 4 cyl Front Wheel Drive Automatic
What is the firing order for a 2000 Malibu 3.1?
LSAUTO
  • 61 POSTS
the firing order is Firing order: 1-2-3-4-5-6. and the coils should have the cyl marked hope this helps lsauto
SODAJOE
1999 Chevy Malibu
what is the firing order and cyclinder placement for a 3.1 v6
RHALL77
  • 3,361 POSTS
https://www.2carpros.com/forum/automotive_pictures/166241_15977_1.jpg
cylinders 2, 4, 6 are at the front of the car 2 being at the front of the engine. 1, 3,5 are at the firewall side of the engine and 1 is starting at the front of the engine
RND
I need a diagram for firing order for coil pack and spark plugs
Here is the cylinder order as well (below) Please let us know if you need anything else to get the problem fixed.
Firing Order .................... 1-2-3-4-5-6
JUSTIN_19
i need a diagram on a v6 3.1 engine on a 1997 chevy malibu LS. Its that i dont know the sequence and i know im supposed to mark them but i thought i knew where they went but i sort forgot where they went so if i can know the order of it or show me a diagram
RHALL77
  • 3,361 POSTS
1,3, 5 are on the firewall side of the engine. #1 ia up front. 2,4,and 6 are on the radiator side. #2 is at the front of the engine. your module should be labeled all ready.
KENDRICK DENSON
1997 Chevy Malibu 6 cyl Two Wheel Drive Automatic
Put in new spark plugs and new wires but dont remember what order the wires go
Sep 28, 2020 at 10:27 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_Wcf_1.jpg
