I went to have car aligned and was told my tie end rods were very loose because the bolts that the rack the rods are attached to have oval out (round bolts and oval bolt hole). No way for him to tighten them. i took it to someone else and they found a hole in the firewall on drivers side and the bolt moves back and forth when you turn the steering wheel. the other person said he could weld a metal plate over the firewall. my question is, can the tie end rods be replaced? the mechanic said it would cost $1,000.00 to take every thing out. thank you for your time.
Sep 18, 2020 at 12:59 PM
