Installing a remote starter need to find ground wire
1999 NISSAN PATHFINDER
200,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
PACEY3182
I had a random question. I'm trying to connect a component and the installation manual tells me to find the wire that "shows ground" under a certain condition. What does this mean and how can I determine this using a multi-meter?
May 16, 2020 at 5:57 AM
Good morning,
What are you trying to install? I need specifics.
As far as the ground, you would need a test light for that. You can get one at any parts store.
May 16, 2020 at 6:41 AM
PACEY3182
I am installing a remote starter, I need to find the wire that shows ground from the park/neutral safety switch connector when the transmission is in park or neutral.
May 16, 2020 at 7:08 AM
Okay, I attached a diagram for you to view. The black wire is the one you need for the ground.
May 16, 2020 at 7:37 AM
PACEY3182
So the black wire will only show ground only when in Park or Neutral?
May 16, 2020 at 7:43 AM
Correct. It will only show ground in park and neutral as the diagram shows.
May 16, 2020 at 8:06 AM
