Fiat X19 With UNO Turbo Engine Disconnected 'Brake Booster Help on Vacuum Pipe'
1980 FIAT
15,000 MILES • 1.6L • 4 CYL • TURBO • RWD • MANUAL
SMITHBB
Good Day Sir , I have a Fiat X19 with UNO Turbo Motor , the car used to have a brake booster that was fitted in the Front Boot area, There was a long vacuum pipe that came from the engine at the rear off car to brake booster at front .
I now disconnected the brake booster as the front braking disc system were modified.
What do I do with the vacuum hose...
Should I block it?
Or should I attach a small breather filter at end off long pipe in front boot compartment .
Please help
God Bless
Mar 23, 2015 at 6:06 AM
WRENCHTECH
  • 20,761 POSTS
Yes, of course you cannot allow it to have a vacuum leak. You might be able to remove the pipe and block it at it's source to make a neater job.
Mar 23, 2015 at 6:42 AM
SMITHBB
Thank you O so much ...
Just a quick 1 .... We're the vacuum hose begins on engine it had a one way valve which sucked air into engine and not blow out to booster.
Is that the way it should be fitted?
Tnx
Mar 23, 2015 at 7:30 AM
