2002 Fiat Uno AC vent fogging condensing Windshield
2002 FIAT UNO
47,000 MILES • 4 CYL • 2WD • MANUAL
SSHYAMB
This happens only when the outside weather is pleasent and I switch the AC on.I need to use the wiper to clear the fogging.Also the condense drain water drips to the mat at the drivers foot.
Can you suggest any foam or material I can use to cover the dashboard vent(Covering the vent with a tape can this damage the AC) and how to avoid dripping.The former problem is in more priority since I cant drive at night with AC on you cannot see anything.The later problem can be adjusted.
Mar 14, 2010 at 12:11 AM
DAVE H
  • 13,384 POSTS
check for a leaking heater core !
Mar 23, 2010 at 5:48 PM
