2004 Fiat Ulysse PROBLEM WITH LIGHTS
2004 FIAT ULYSSE
SMUDGEDM
2004 Fiat Ulysse 4 cyl Front Wheel Drive Manual
MAIN BEAM HEADLIGHTS ARE STAYING ON EVEN AFTER TURNING THE SWITCH OFF, REMOVING KEY FROM IGNITION AND LOCKING ALL DOORS. THE ONLY WAY TO RECTIFY TEMPORARILY IS TO REMOVE THE TWO FUSES FROM THE ENGINE COMPARTMENT FUSE BOX.
I KNOW THE OBVIOUS ANSWER IS TO REPLACE THE INDICATOR/WIPER SWITCH ASSEMBLY ON THE STEERING COLUMN, BUT THIS HAS ALREADY BEEN DONE AND THE PROBLEM HAS COME BACK.
ANY IDEAS???
MANY THANKS, DAMIAN
Mar 2, 2009 at 4:44 PM
DAVE H
  • 13,384 POSTS
check for relay fault and wiring !
Mar 21, 2009 at 10:23 AM
