1978 Fiat Spider Metal grinding noise
1978 FIAT SPIDER
MCK68W
Noises problem
1978 Fiat Spider 4 cyl Two Wheel Drive Manual ?????? miles
After stopping at a light, the car started making a high pitch metallic grinding noise, seemingly coming from the passenger side of the engine near the exhaust cam cover. It actually died at idle at the next light, and I found that I could keep it running if I set the idle adjustment a little higher. The engine seems like it is dragging. I removed the V belt and cranked it and the sound was still there. Checked the valvetrain, nothing seems wrong there. The noise corresponds with engine speed and load, sounds almost whiny at higher speed, and like imminent doom metal on metal at low rpm with load. I'm hoping not to have to go digging for the source...
Oct 22, 2010 at 6:32 PM
DAVE H
  • 13,384 POSTS
start by checking the timing belt has no broken stripped teeth
Jan 23, 2011 at 3:07 PM
