1996 Other Fiat Models Loose clutch
1996 FIAT
N1KE
1996 Other Fiat Models 75,000 miles
The clutch pedal of the car (Fiat Punto, 1246cc) has lost its tension, it went all the way down when I pressed it with no resistance at all. I can't change the gear when the engiine is on. I spoke to a mechanic who told me the car doesn't use a clutch cable but mentioned something about the piston needing replacement. My question is what do you think is wrong and what does the piston do? thanks
Mar 26, 2008 at 7:53 AM
DAVE H
  • 13,384 POSTS
the piston is inside the clutch slave cylinder .. the whole cylinder needs replacing .. the cylinder/piston uses fluid to push the clutch !!
Nov 8, 2009 at 5:15 AM
