feels like chocking
1998 SATURN SL1
251,000 MILES
BBARBO9
  • 86 POSTS
When I start the car its starts and will go up and down on the rpm and slowly go down till it will cut off. if I give just a little gas it will cut off right away. but if I floor it white smoke comes out and it will just then rough idle a little. When I take off sometimes it takes off fine and sometimes it seems like no matter how hard I hit the gas when or how I shift it still goes slow like its being chocked.
May 3, 2013 at 11:24 PM
SATURNTECH9
  • 30,869 POSTS
have you checked the coolant temp sensor and connector yet?
May 4, 2013 at 5:07 PM
BBARBO9
  • 86 POSTS
no I haven't honestly I didn't even think about nothing like that. I just noticed today that I drove for an hr and a half and it stayed on cold it didn't budge...so yeah
May 8, 2013 at 9:57 PM
SATURNTECH9
  • 30,869 POSTS
Then that's the first thing I would check.
May 9, 2013 at 7:32 AM
BBARBO9
  • 86 POSTS
Can you check it without getting a new one
May 9, 2013 at 7:25 PM
SATURNTECH9
  • 30,869 POSTS
You can but the sensor is only 11 also you can check the sensor with a multimeter.but it's best to check it with a scan tool that reads live data and a infard temp gun.
May 9, 2013 at 8:24 PM
SATURNTECH9
  • 30,869 POSTS
Also inspect the inside of the connector if the terminals are blue or green instead of silver then you need to replace the connector also.
May 9, 2013 at 8:27 PM
