The car does not shift into forth gear, and code p0734 is set. i changed out the transmission with another one (used ) and nothing changed. I also changed the PCM with another one (used ) and nothing changed. i noticed that oxygen sensor is not working properly. My question is, can the oxygen sensor faulty or engine misfire effect on transmission shifting into forth gear only and set code p0734?
May 8, 2016 at 9:13 AM
