fault in can communications with N73 EZS control module?
2005 MERCEDES BENZ C200
138,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
ALAEDDIN IBRAHIM BEN GHARBIA
my car has gear shift level disappeared from IC , the ac condition unavailable on can bus means not running , parktronic does not working no volts for bumpers but it is working with no fault and flashing when ignition on only reverse lights does not go on when r gear in but from SAM test it is light on audio 20 fault can communication with N73 both SAMs f and rear fault is also can N73 fault can communication.
Jul 6, 2023 at 6:22 PM
Can I ask if a CAN scan was done? You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
We should start by checking the fuses, here is a guide that should help.
The Audio 20 fault suggests a problem with the audio system. If both the front and rear SAM modules are experiencing faults, it could indicate a problem with the modules themselves or a wiring issue. Similarly, if the N73 module (which is responsible for communication) is also experiencing faults, it could be related to a wiring issue or a malfunctioning module.
It is common for the SAM modules to go out if all fuses are good, I would try swapping the SAM module out. Here is how in the images below.
Jul 7, 2023 at 11:42 AM
Thanks a lot fixed change ECU and ezs and els and now everything back to work.
Jul 10, 2023 at 4:27 AM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jul 10, 2023 at 10:32 AM
