Batter drain and fault codes A10A and A10D
2009 MERCEDES BENZ C220
80,000 MILES • 3.0L • 6 CYL • TURBO • 4WD • AUTOMATIC
GRENGHASSAN
Car Reg: KS58NYA
I have experienced an issue my my car. It drains the battery.
I have done a diagnostic test and it brings up codes.
A10A - Voltage supply too low
A10D - Voltage supply too low
Can you please advise?
Thanks
Greng
May 6, 2020 at 8:00 AM
First take a look through this link. It discusses common simple causes of battery drain.
https://www.2carpros.com/articles/car-battery-dead-overnight
If nothing there helps, I need you to check for the alternator output. Follow this link:
Do these two things and let me know the results.
May 6, 2020 at 9:28 AM
GRENGHASSAN
Hi Joe,
Yes, I have read all these before and I did a diagnosed test. It comes back with the codes I have sent before?
Can you understand the fault code? It is related to anything?
I have tested the alternator and it responded!
Thanks,
Greng
May 6, 2020 at 10:09 AM
I have searched everything I have and do not see those codes. I need you to do me a favor. Have the computer scanned for codes using an OBD2 scanner. Here is a quick video showing how it is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but most parts stored will do it free of charge. Have that done and let me know what codes are found. They will likely be different numbers indicating the same problem.
May 7, 2020 at 7:50 AM
GRENGHASSAN
Hi Joe,
Here is the photo of the code that came up. See if you can find anything!
I will see if I can get get OBD2 done I will let you know. Please let me know if you can find anything from the picture I sent you
Thanks,
Greng
May 7, 2020 at 8:00 AM
Honestly, Mercedes is very secretive with some things. However, by law they have to provide an OBD2 system. When you scan it, the codes will likely be different but mean the same thing.
Let me know what you find.
May 7, 2020 at 8:53 PM
