I have a code p0214 that comes in about 5 seconds after cranking and a code p0327 that comes in after warm up or during KOER tests. I've checked resistance and voltage on the DPFE and they seem within range.
The issue that started me looking was into a twenty minute trip on several occasions, the engine would bog down when attempting to accelerate. As long as I backed off, it would run smooth. I also discovered that if I gave it WOT, it would also smooth out and accelerate responsively.
After letting the engine cool off, it runs smooth again until around 20 minutes into the drive.
Any ideas? Can I leave the diagnostic plug hooked up to capture running codes when it happens?
Thanks,
Mark
Thanks,
Mark
Jul 4, 2019 at 12:14 PM
