Fatal safe mode low oil pressure
2005 FORD EXPLORER
MARIETHOMPD
Cut off came up fatal safe mode low oil pressure has good oil level hooked to computer no codes came up checked pressure on oil pump over 200. What could it be? Changed sending sensor not sure what else to check.
Aug 30, 2013 at 8:08 AM
If you have 200 lbs of oil pressure, I can't believe the oil filter hasn't ruptured. If that is the case, the relief valve, which is built into the oil pump, must not be working.
Aug 30, 2013 at 8:41 PM
I just reviewed your post. Is the pressure low or extremely high? If it is 200 lbs, that is EXTREMELY high. Let me know. Also, let me know if you checked pressure with a mechanical gauge.
Aug 30, 2013 at 8:43 PM
MARIETHOMPD
He said it is with a mechanical gauge maybe the pump valve is stopped up.
Aug 31, 2013 at 7:41 AM
MARIETHOMPD
Can the valve be changed or would it be best to just change the oil pump.
Aug 31, 2013 at 7:43 AM
With labor, it would cost more to replace the valve. I would recommend replacing the pump. By the way, is the pressure that high? If so, check the oil filter to make sure it isn't damaged or leaking.
Aug 31, 2013 at 7:06 PM
