fastener tightening specifications
2013 CHEVROLET MALIBU
111,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
TERRENCE WOGAN II
  • 14 POSTS
I am having problems finding any answers to this specific engine on the internet. My car listed above has a turbo automatic 6 speed transmission. My vacuum pump on the end of my exhaust camshaft froze or broke and ended up binding up and bending the exhaust camshaft. Beyond finding parts because of GM strike i cannot find out what kind of sealant to use on the side plate going back on and i need to know to torque on such plate the cam bolts and arms on the cam as well as the valve cover bolts. and anything else i would need to know or should know putting everything back together from the timing chain to complete install that normally would be missed.
Oct 20, 2019 at 1:46 PM
TERRENCE WOGAN II
  • 14 POSTS
I have gotten 3 emails saying i have new answers but i see none.
Oct 20, 2019 at 4:32 PM
STEVE W.
  • 15,113 POSTS
Yeah, there is a strange glitch in the system. I'm going to try again with different pictures.
Oct 20, 2019 at 4:34 PM
TERRENCE WOGAN II
  • 14 POSTS
Okay, thank you. Means a lot.
Oct 20, 2019 at 4:36 PM
STEVE W.
  • 15,113 POSTS
I tried a few more times and it refuses to post the information. Wipes out even plain text for some reason.
Oct 20, 2019 at 4:46 PM
TERRENCE WOGAN II
  • 14 POSTS
So I'll wait for it?
Oct 20, 2019 at 4:55 PM
STEVE W.
  • 15,113 POSTS
I'm trying to get it to post. There is something wrong, not sure if it's the post, pictures or what at the moment, but I'll keep trying. The front cover sealant is sensor safe rtv.
Oct 20, 2019 at 5:05 PM
STEVE W.
  • 15,113 POSTS
applied as in image Spot 1 is a 5mm bead, 2 is a 5mm bead, 3 is a 14 mm dab.
Oct 20, 2019 at 5:06 PM
STEVE W.
  • 15,113 POSTS
The cover torque is a sequence. These are new bolts for 1 through 3
1 and 3 first pass to 11lb ft. final pass of 130 degrees
4 to 15 all to 18ft.lb
16 to 19 are 89 inch pounds
number 20 is 18 ft.lb.
Oct 20, 2019 at 5:10 PM
STEVE W.
  • 15,113 POSTS
That what you were looking for?
Oct 20, 2019 at 5:18 PM
TERRENCE WOGAN II
  • 14 POSTS
Yes sir and cam sprocket bolts and valve cover but you have done a lot already.
Oct 20, 2019 at 5:28 PM
STEVE W.
  • 15,113 POSTS
Cam cover - 89 inch pounds.
Cam actuator bolt - 22ft lb plus 100 degrees.
Do you have the special tool to lock the cam in? EN 50793
Oct 20, 2019 at 5:36 PM
TERRENCE WOGAN II
  • 14 POSTS
No. looking it up trying to understand it. guessing I need this?
Oct 20, 2019 at 5:52 PM
TERRENCE WOGAN II
  • 14 POSTS
Is it necessary or a way to lock actuators otherwise?
Oct 20, 2019 at 5:53 PM
TERRENCE WOGAN II
  • 14 POSTS
Also on the intake side with the plate on it doesn't have the notch to sit it.
Oct 20, 2019 at 5:58 PM
TERRENCE WOGAN II
  • 14 POSTS
Its vvt actuator on intake cam as well, as per illustration tool can only be used on exhaust cam actuator. So how would the vvt actuator be held on intake side?
Oct 20, 2019 at 6:05 PM
TERRENCE WOGAN II
  • 14 POSTS
..as per illustration tool can only be used on exhaust cam actuator. So how would the vvt actuator. Be held on intake side
Oct 20, 2019 at 6:14 PM
STEVE W.
  • 15,113 POSTS
You are supposed to have the timing chain on and set the timing and then use a tool EN-50656 to lock the chain, then the other tool locks the exhaust side.
Oct 20, 2019 at 8:08 PM
TERRENCE WOGAN II
  • 14 POSTS
Thank you.
Surprise tool number 2. any other ones I should be aware of?
Oct 20, 2019 at 8:19 PM
TERRENCE WOGAN II
  • 14 POSTS
So you torque the intake cam before you put cover on. in trying to understand when to torque the intake cam actuator cause of the vvt on both intake and exhaust.
Oct 20, 2019 at 8:22 PM
STEVE W.
  • 15,113 POSTS
It's a strange system, but you place the intake cam into the exhaust cam position, then install the locking tool, and install the actuator and bolt and torque it down. Now remove the locking tool and lift and roll the intake cam under the timing chain across the head into it's correct position and as close as possible to it's timing marks. Now you can put the exhaust camshaft into place and install it's actuator and time both cams to the correct spot. You need the locking tool to hold things in place as you torque the bolts. The timing chain lock is normally used when you are taking the cams out, it holds the chain up and keeps it from releasing the tensioner.
Oct 21, 2019 at 5:57 AM
TERRENCE WOGAN II
  • 14 POSTS
Thank you. yes, very strange system but we get it now.
Oct 21, 2019 at 9:03 AM
STEVE W.
  • 15,113 POSTS
Probably would have cost them a whole 30 cents to have a notch on both sides to make it easier. At the moment it's fun to even get parts being the UAW is on strike again, GM may not exist much longer.
Anyway, keep us informed and ask if you need anything else I think the posting issue has been cured.
Oct 21, 2019 at 12:34 PM
TERRENCE WOGAN II
  • 14 POSTS
Torque on harmonic balancer is only thing else I can't find. Otherwise everything you helped me with was awesome.
Oct 24, 2019 at 4:42 PM
STEVE W.
  • 15,113 POSTS
Using a new bolt torque to 111 ft.lb. then add 140 degrees.
Oct 24, 2019 at 6:32 PM
