Hello again,
The catalytic converter is used further down in the exhaust. It's job is to take harmful exhaust pollutants and break them down into non harmful byproducts, such as water for example. The Exhaust Gas Recirculation[EGR] is used to take exhaust gas, before it goes to the catalytic converter, and is reintroduced into the engine's combustion chamber through the throttle body or intake manifold when the Power-train Control Module[PCM] determines that the conditions are right for it to be burned. This is undoubtedly what melted the hoses as the tube coming from the exhaust manifold get very hot with exhaust gas. Ensure it is routed correctly or that heat wrap is around where it comes close to other components. I hope this helps.
Thanks,
Alex
2CarPros
Nov 1, 2019 at 12:04 AM
