I just had to replace the radiator and A/C condenser due to the jack slipping and smashing them. I followed the repair manual in burping the air out of the radiator and pulled a vacuum on the A/C system, but did not put refrigerant back in it. Since then neither fan turns of once it reaches operating temperature, it is around 20-30 degrees Fahrenheit out now. The upper fan already had problems where it needed tapped sometimes to turn back on. I have checked the wiring harnesses and they are both plugged back in properly. Does the A/C system need to be charged for fans to work?
Nov 11, 2020 at 6:54 PM
