Cooling fans and A/C fans not turning off
2014 CHEVROLET SILVERADO
113,453 MILES • 5.3L • V8 • 2WD
LARRY1521
  • 4 POSTS
Cooling fans and A/C keep running with the key off.
Jan 28, 2019 at 3:22 PM
Good evening,
Does the compressor clutch stay engaged as well or just the blower motor and the cooling fan?
The PCM is what controls the cooling fans. Good chance it may need the PCM replaced.
Are there any codes?
Jan 28, 2019 at 4:36 PM
LARRY1521
  • 4 POSTS
No code just cooling fans I unplugged the battery for about 20-30 minute now the fans off but the temperature gauge read a little before normal is that ok
Jan 28, 2019 at 4:55 PM
The gauge should not read anything with the key off.
Jan 28, 2019 at 5:05 PM
LARRY1521
  • 4 POSTS
No it reads zero with the key off, but I’m saying when the truck is running it used to read to 210 and now it reads 200. is that fine?
Jan 28, 2019 at 6:07 PM
Yes, that is good.
Jan 29, 2019 at 2:15 AM
LARRY1521
  • 4 POSTS
Thank you.
Jan 29, 2019 at 12:11 PM
You are welcome.
always glad to help.
Jan 29, 2019 at 2:15 PM
