I did the fan direct but the switch is there and it is not going off. so I want to remove the light the low fan for engine.
Jan 2, 2017 at 8:04 AM
ABDUR RAHMAN 123
MEMBER
Temperature switch is not working so what should I do?
Dec 18, 2018 at 6:32 PM
ABDUR RAHMAN 123
MEMBER
It is an automatic.
HMAC300
CERTIFIED EXPERT
check fuses and relays in picture. then check resistance of engine cooling switch. See pictures. resistance is an example of what it should read, higher when cold.
