This is a friend if mine's car. we replaced the thermostat and water pump 2 months ago because the pump failed and car was overheating. yesterday he was driving home and it overheated, he checked water level was low so he added some and drove it home. he removed the coolant temperature sensor so the fan can come on high to help with the heating until he came home. i checked it today and i saw faults that are not present such as water pump speed deviation, o2, and catalyticone, deleted all and started the car and let it warm, o2 and catalytic one are present i don't see anything else, unplugged coolant temperature sensor and fan came on high. Plugged it back and turned A/C on but fan did not come on immediately. Turned on after couple of minutes. Turned A/C off and fan shut off. Now at 169F coolant temperature and 156 at radiator outlet the speed of the electric coolant pump is at 0. Now at 200 and the water pump speed is zero, am not sure if the electrical connector could have come off or what. I will have to jack it up, but anyways if the pump is bad when is the coolant fan supposed to kick in at what temperature?
Am thinking since the pump is totally dead it could be a fuse, one under the hood passenger side, but there ate also fuses in the glove box, can you get me the diagram for it so I will know which it is? Its a tight fit
Jan 21, 2020 at 1:41 PM
