i can hear a fan noise. This noise can happen when AC is off or on. So I am sure it is not the AC fan. I need your help.
Jan 22, 2018 at 10:25 PM
STEVE W.
CERTIFIED EXPERT
Where do you hear the noise? inside the car or outside? If it is the cooling fan on the radiator and it is staying on even with a cold engine it could be a faulty coolant temperature sending unit, bad fan controller or faulty fan relay. To actually test them and determine where the fault is you need a scan tool that can read the live data from the sensors and that can activate the fan control relay.
