Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Ram
Engine Cooling
Cooling Fan
Relay
Location
Fan cooling relay location where it's by the grille?
2012 DODGE RAM
136,000 MILES • 4WD • AUTOMATIC
MAPESCUT
MEMBER
FOLLOW
Where is that located? Seen one video where it's by the grille and another up in the fuse relay box.
Jul 18, 2020 at 5:09 AM
CERTIFIED EXPERT
Good morning,
Yes, they were correct. There is a relay at the front grille and one on the fuse block. They are for high speed and low speed operation.
I attached the locations for you of the relays.
What is the issue? I also attached a wiring diagram for you for testing. If you have a test light or voltmeter we can do some testing.
Jul 18, 2020 at 5:30 AM
MAPESCUT
MEMBER
Thank you found it and fixed it!
Jul 19, 2020 at 7:00 AM
CERTIFIED EXPERT
You are welcome.
Always glad to help.
Jul 19, 2020 at 7:01 AM
